Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
Randy5235
Dec 06, 2016Aspirant
Looking further into it, the option is there but is commented out in the source code. Uncommenting it does not work as expected sadly. I will dig into this further as time allows
brandoncbarker
Dec 07, 2016Tutor
Does Netgear ever respond to questions? Seems to be empty on any r9000 related ones :/
- mondenathDec 08, 2016Prodigy
Are you guys in the new firmware. It seems you are still not in upto date firmware.
Check if you can get this working after updating the latest by using the notice ballon on the top and see if the new firmware works.
- AdewaleDec 08, 2016Luminary
i check for a firmware update anytime i log into the web UI or fire up genie...on firmware version 1.0.1.20
- Lexist2112Dec 08, 2016Luminary
I'm only see FW .20 on the website, unless the Netgear servers haven't released it .
- Randy5235Dec 08, 2016Aspirant
If you reread my post, you will see that I have tried the latest and that I rolled back in an attempt to resolve this issue. Still no luck here.
