Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
CyberTri
Mar 26, 2017Apprentice
Also, having the ability to do at least 4 or 5 vlan tags, and some real LAN firewall rules should be a given on these units. I don't see why there are not some simple IP and port permit/deny options. Wouldn't that make the device fierce competition to the industry outside of pure home consumers?
I mean ...my cheap Cisco ASA 505 is great for vlans and fw rules.
JamesGL
Mar 29, 2017NETGEAR Employee Retired
Hi CyberTi,
You can check the new firmware for the device that supports Dynamic QoS.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-Beta-Firmware-1-0-2-18/td-p/1249132
- schumakuMar 30, 2017Guru - Experienced User
JamesGL wrote:You can check the new firmware for the device that supports Dynamic QoS.
It allows to define the Device Priority with the attached device list. Perfectly sufficient for most applications in my opinion.
For now, this seems to be limited to the Web UI, this control is not available in the Genie App for macOS, Windows, Android, ..
- ElaineMApr 12, 2017NETGEAR Employee Retired
Hey all, we have updated the QoS Database.
Release date is on April 12, 2017.
Feel free to provide your feedback.- schumakuApr 23, 2017Guru - Experienced User
ElaineM wrote:Hey all, we have updated the QoS Database.
Hi ElaineM,
Is 12 April the day it became available, or is this supposed to be the release date? Asking, because my R9000 does show this:
Current Performance Optimization Database on Router
Version: netgear-detection-db-v1.3
Release Date: Mar 22 2017Regards,
-Kurt
- pdeering100Apr 23, 2017Tutor
Just bought the R9000 and could not find QoS.
Did the firmware update and still not there.
What is the status on release?
Thank you,
pdeering100 wrote:Just bought the R9000 and could not find QoS.
Whatever you have installed, crystal ball is on a holiday with grand aunt in Transylvania in the land of Dracula these days. Of course I have an idea ... the official download is still stuck on 1.0.1.18 8-/
We're menawhile talking here of a Beta 1.0.2.18 listed here in the forum sticky topics -> https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-Beta-Firmware-1-0-2-18/m-p/1249132#U1249132 ... the official release is delayed due to some kind of reliability issues (and a long list of open issues...).
Regards
-Kurt
- Lexist2112Apr 25, 2017Luminary
Elaine, when is Netgear going to "officially" release the new firmware???
