Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
JamesGL
Mar 29, 2017NETGEAR Employee Retired
Hi CyberTi,
You can check the new firmware for the device that supports Dynamic QoS.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-Beta-Firmware-1-0-2-18/td-p/1249132
schumaku
Mar 30, 2017Guru - Experienced User
JamesGL wrote:You can check the new firmware for the device that supports Dynamic QoS.
It allows to define the Device Priority with the attached device list. Perfectly sufficient for most applications in my opinion.
For now, this seems to be limited to the Web UI, this control is not available in the Genie App for macOS, Windows, Android, ..
- ElaineMApr 12, 2017NETGEAR Employee Retired
Hey all, we have updated the QoS Database.
Release date is on April 12, 2017.
Feel free to provide your feedback.- schumakuApr 23, 2017Guru - Experienced User
ElaineM wrote:Hey all, we have updated the QoS Database.
Hi ElaineM,
Is 12 April the day it became available, or is this supposed to be the release date? Asking, because my R9000 does show this:
Current Performance Optimization Database on Router
Version: netgear-detection-db-v1.3
Release Date: Mar 22 2017Regards,
-Kurt
- BouldaJun 05, 2017Tutor
Feel free to provide your feedback.How does one update this database? My router says March is the latest version.
I am running firmware 1.0.2.32
- FURRYe38Jun 05, 2017Guru - Experienced User
It Auto updates on it's own. Nothing to do on your side.
- BouldaJun 17, 2017Tutor
Feel free to provide your feedback.I would do, if I could update to it.
- FURRYe38Jun 17, 2017Guru - Experienced User
You might try this, download the lastest version of the FW. Use IE11 or FF, clear all browser caches before and after loading the FW. Do a factory reset, manally load the FW, factory reset and set up once more. Enable Dynamic QoS and leave it. Check the date and if nothing has changed to April, come back day two or three days later and check on it.
What is your ISP Mfr and model# modem?
- pdeering100Apr 23, 2017Tutor
Just bought the R9000 and could not find QoS.
Did the firmware update and still not there.
What is the status on release?
Thank you,
pdeering100 wrote:Just bought the R9000 and could not find QoS.
Whatever you have installed, crystal ball is on a holiday with grand aunt in Transylvania in the land of Dracula these days. Of course I have an idea ... the official download is still stuck on 1.0.1.18 8-/
We're menawhile talking here of a Beta 1.0.2.18 listed here in the forum sticky topics -> https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R9000-Beta-Firmware-1-0-2-18/m-p/1249132#U1249132 ... the official release is delayed due to some kind of reliability issues (and a long list of open issues...).
Regards
-Kurt
- Lexist2112Apr 25, 2017Luminary
Elaine, when is Netgear going to "officially" release the new firmware???
