Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
CyberTri
May 25, 2017Apprentice
I will wait for schumaku to check it. Lol
schumaku
May 25, 2017Guru - Experienced User
Thank you for the flowers :smileymad:
I'm in the lucky(?) position operating 1.0.2.32 for some days already. It works pretty much reliably, if the Dynamic QoS thing with the by-connected-device (the lConnected Device ist is more or less reliably updated) priority setting (which is in place on Connected Devices - Edit) can fulifill all users expectation ... I can't judge. For best throughput, and to avoid unexpected dynamic changes ... I pefer to have the QoS and DoS protection mostly disabled.
Beyond, it feels and behaves like the 1.0.2.30 which has seen disabling the QoS thing on a short note for a quick release I guess.
There are - on my high expectations - lots of security issues unresolved ...
