Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
schumaku
Jun 17, 2017Guru - Experienced User
Does anybody really see April 12, 2017?
Can't get rid of the impression there are two release dates - one in the QoS database, and the effective date it was released.
Can't be we have to nurse the R9000, play browser compatibility fig and cache, reset, and so on. We talk of a product here - not a PoJ.
- schumakuJun 19, 2017Guru - Experienced User
All right, following an email exchange with the Netgear PM in Taiwan, they uploaded the v1.12, with a release date 25 Myy 2017 to the update server - so this is available for about one hour now.
- FURRYe38Jun 19, 2017Guru - Experienced User
I'm still at on my R7800:
Current Performance Optimization Database on Router
Version: v4.0428.g33cf1a0
Release Date: April 28, 2017
How does the update get pushed to the routers? Reboot or Factory reset? This update only for the R9000 data base or all NG routers?
R7800 is off-topic here, no idea.
For the R9000, I was told the push the new QoS DB for the R9000 to the server, and someminutes later I've triggered a manual update check, which succeeded. So either they maintain an XML feed, or are using a hardcoded direct download URL.
- BouldaJun 19, 2017Tutor
Mine has finally updated. It is now 25 May 2017
