Randy5235
Dec 05, 2016Aspirant
R9000 qos settings are missing.
I just purchased the R9000. I am trying to set up the QOS rules but if I go to Advanced -> Setup -> QOS Setup; I am only seeing WMM settings there. I have tried on both 1.0.1.20 and 1.0.1.18 version...
- May 25, 2017
Hello All, we just released the firmware for R9000 with Dynamic QoS.
https://kb.netgear.com/000038782/R9000-Firmware-Version-1-0-2-32
schumaku
Jun 19, 2017Guru - Experienced User
All right, following an email exchange with the Netgear PM in Taiwan, they uploaded the v1.12, with a release date 25 Myy 2017 to the update server - so this is available for about one hour now.
I'm still at on my R7800:
Current Performance Optimization Database on Router
Version: v4.0428.g33cf1a0
Release Date: April 28, 2017
How does the update get pushed to the routers? Reboot or Factory reset? This update only for the R9000 data base or all NG routers?
- schumakuJun 19, 2017Guru - Experienced User
R7800 is off-topic here, no idea.
For the R9000, I was told the push the new QoS DB for the R9000 to the server, and someminutes later I've triggered a manual update check, which succeeded. So either they maintain an XML feed, or are using a hardcoded direct download URL.
