sbray112
May 11, 2018Tutor
R9000 ReadyCloud not working
I updated to V1.0.3.16 and Readycloud stopped working. I thought I would try derigestering and register the device again in the readyshare tab. now it says "Registration failed. Please check your use...
- May 18, 2018
Just Installed Firmware V1.0.4.2 that seems to have fixed it. Thanks for ALL the suggestions! :smileyfrustrated:
sbray112
May 18, 2018Tutor
Guigui97233 wrote:
I did a reset on my r9000 and now i dont even have a « register » button in the readyshare TAB of the router’s admin page so i can apply my username and password ....
Have you installed firmware V1.0.4.2. seems to have fixed my problem.
Guigui97233
May 18, 2018Guide
I have installed the 1.0.4.2 version , then i did a factory reset, then i re configured all my settings on the router but i still cannot add my readycloud information in the admin page. Its like i can write my username and my password but there is nothing to click « apply » or « save » ..... i tried to click enter on my keyboard but nothing happened, i have also tried on different browser and on my iphone or ipad its the same problem... impossible to connect to the readycloud :/
- sbray112May 18, 2018Tutor
Thats crazy. Mine broke on V1.0.3.16 saying the registration failed. when I installed V1.0.4.2 it fixed it. Maybe try installing older firmware then reinstall new firmware? thats what i was gonna try until the new firmware came out.- Guigui97233May 18, 2018GuideI will try everything possible lol .... but this is crazy as you said ... how is it possible for a company to sell a product with so much bugs ... every update is comming with a new problem ...
