sandymar123
Dec 11, 2020Tutor
R9000 router password recovery does not work
I forgot my admin password to the router. The router is functioning properly but I want to get into admin. I used the password recovery feature which I did set and I answered the 2 easy questions. ...
sandymar123
Dec 11, 2020Tutor
Thank you for your response. I recall that the person who originally assisted me in setting up the software for my cameras needed to do some port forwarding. Do you think I will lose those cameras with the hard reset?
Dec 11, 2020Guru - Experienced User
tough to say if you will or not. Maybe...
Again, it depends on why it needed port forwarding.
I've got several security cameras and haven't needed to a single port forward
- sandymar123Dec 11, 2020Tutor
thanks for your help! Happy Holidays and stay safe!
- plemansDec 11, 2020Guru - Experienced UserGood luck!
