kyndrion
Oct 09, 2021Follower
R9000 selectively slow LAN
Ok, been through the assorted posts but cannot find anything specific to my current issue. I have a 250Mbps down plan but speed test in browser rarely exceeds 100. When I skip the router and plug int...
Oct 10, 2021Guru - Experienced User
what modem/gateway is it connected to?
What 5ghz speeds do you get?
What 2.4ghz speeds do you get?
What wired speeds?
Have you tried factory resetting and reinstalling?
What port speeds are showing in the statistics page (screen snip it).
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
