Wolfangovich
Sep 26, 2022Aspirant
R9000 showing Ethernet connections as Wireless Connections.
My R9000 is on firmware 1.0.5.42
I have 7/8 devices connected with CAT6.
These devices all connect to a Netgear GS724TPS which is then connected to the Netgear R9000
When I reboot the R9000 it shows everything that is connected via Ethernet, that they are connected via Ethernet.
After a couple of minutes, the screen refreshes on the R9000
Then only 1 device is showing as connected via Ethernet.
It shows the rest as connected via Wireless connections even though, Wireless is turned off and they machines are only connected via Ethernet.
This just started after the firmware upgrade, not sure what has changed.
Any help would be appreciated.
Thanks
1 Reply
Got a screen capture of this you can post here?
Does this happen with out the switch in the middle?
