kription
Nov 29, 2020Follower
R9000 Slow Wired/LAN performance
I've tested the following situations and in each the LAN performance test it has not exceeded 55Mbps (both intranet and internet).
Netgear:
Firmware Version 1.0.5.18
Firmware Version 1.0.5.24
Voxel:
R9000-V1.0.4.45HF.zip
R9000-V1.0.4.45.2HF.zip
Tests included using Speedtest.net across multiple server locations, on a gigabit connection, directly connected to a SB8600 modem. Tests on the intranet were done using simple file copy, LAN Speed Test Lite, iperf, and rsync [progress flag] in all cases, machines were directly connected to R9000.
This wireless and wired connection was verified using other routers (ASUS RT-AC68U, Google Nest 2020, TP-Link AC1750), and in each case performance exceeded 900Mbps when directly connected to the routers or in the case of the Nest - via a switch connected to the router.
Multple cables were tested, from basic cat-5 through cat-7, none exceeding 10 feet.
All LAG was disabled, as was any QOS.
Ports 2-8 were tested in each case and they all perform equally poorly.
What am I missing?
1 Reply
- DarrenMSr. NETGEAR Moderator
This could be a hardware issue. I suggest contacting support.
https://www.netgear.com/support/contact.aspx
DarrenM
