Hammer68
Dec 14, 2016Star
R9000 VPN not working.
My VPN was working fine before I had the 2.4ghz channel stop sending a SSID. Restored router to original settings then setup the same way before. 2.4ghz is back but now VPN is not working. I re downlo...
- Dec 24, 2016*******Update*********
Swapped router today for a new one and setup everything the same except Plex Media Server. VPN is now working perfectly on iPhone and no issues with 2.4ghz channel. Hopefully I will not have any issues with this unit. If I do I will change brands and not look back. Thanks for those of you who offered help.
Hammer68
Dec 18, 2016Star
Bumping this back up, spent hours trying to get this working on my iPhone.
DynamicDNS Setup - Yes
OpenVPN Enabled - Yes
Tested on Mac with Tunnelblick and worked fine.
Getting NotReachable error in log.
ElaineM
Dec 20, 2016NETGEAR Employee Retired
Tried reinstalling the firmware?
If you did, I suggest that you contact support for them to log a case for you.
