Hammer68
Dec 14, 2016Star
R9000 VPN not working.
My VPN was working fine before I had the 2.4ghz channel stop sending a SSID. Restored router to original settings then setup the same way before. 2.4ghz is back but now VPN is not working. I re downlo...
- Dec 24, 2016*******Update*********
Swapped router today for a new one and setup everything the same except Plex Media Server. VPN is now working perfectly on iPhone and no issues with 2.4ghz channel. Hopefully I will not have any issues with this unit. If I do I will change brands and not look back. Thanks for those of you who offered help.
ElaineM
Dec 20, 2016NETGEAR Employee Retired
Tried reinstalling the firmware?
If you did, I suggest that you contact support for them to log a case for you.
Hammer68
Dec 21, 2016Star
Not going to put up with it, going to go swap it out where I bought it since its only a few weeks old and already having issues.
- rmsarmaDec 21, 2016Guide
I am having simiar issues and netgear support is really unresponsive i am planning to send mine back as well
case #27803851
