Hammer68
Dec 14, 2016Star
R9000 VPN not working.
My VPN was working fine before I had the 2.4ghz channel stop sending a SSID. Restored router to original settings then setup the same way before. 2.4ghz is back but now VPN is not working. I re downlo...
- Dec 24, 2016*******Update*********
Swapped router today for a new one and setup everything the same except Plex Media Server. VPN is now working perfectly on iPhone and no issues with 2.4ghz channel. Hopefully I will not have any issues with this unit. If I do I will change brands and not look back. Thanks for those of you who offered help.
Hammer68
Dec 21, 2016Star
Not going to put up with it, going to go swap it out where I bought it since its only a few weeks old and already having issues.
rmsarma
Dec 21, 2016Guide
I am having simiar issues and netgear support is really unresponsive i am planning to send mine back as well
case #27803851
