Hammer68
Dec 14, 2016Star
R9000 VPN not working.
My VPN was working fine before I had the 2.4ghz channel stop sending a SSID. Restored router to original settings then setup the same way before. 2.4ghz is back but now VPN is not working. I re downlo...
- Dec 24, 2016*******Update*********
Swapped router today for a new one and setup everything the same except Plex Media Server. VPN is now working perfectly on iPhone and no issues with 2.4ghz channel. Hopefully I will not have any issues with this unit. If I do I will change brands and not look back. Thanks for those of you who offered help.
TonyPHX
Dec 22, 2016Guide
Seems like you have done everything right on your side.
By chance, you don't have any conflicting port forwarding? That's the last and only thing I can even think of.
Mine is working, but yes, i did initially have problems.
Ohhh this reminds me of one thing... how did you copy the file to the OpenVPN client? Don't send through email. Something goes wrong for me when I do that.
Dec 22, 2016Guru - Experienced User
For iOS (ipad) I combine the files in the netgear zip to a unified ovpn file. I find that is easier. If you google OpenVPN unified format you will find the information you need on the syntax.
I don't know why Netgear doesn't use the unified format.
- TonyPHXDec 22, 2016Guide
Yes, Sorry Stephen. I should have been clear, I know how to move the files. I should have just said, I suggest not emailing the indiviual files to the device.
Also, for the R9000, the smartphone is the unified opvn file that you retrieve from the router interface.
- StephenBDec 22, 2016Guru - Experienced User
Glad they changed that, but I wish they'd apply it to other Nighthawk routers. I get a zip file when I download with separate files (ca.crt, client.crt, client.key, and client3.opvn). It's a nuisance.
Agreed. That never made sense to me.
Incidentally, the unified opvn file is the only "generated" one that worked for me using Tunnelblick on Mac. The others for windows and non-windows did not build a working package. Thus why we see a lot of people say VPN isn't working for them on the R9000. I did speak with Netgear support, and tried to help, but they concluded there is no problem. : )
