Hammer68
Dec 14, 2016Star
R9000 VPN not working.
My VPN was working fine before I had the 2.4ghz channel stop sending a SSID. Restored router to original settings then setup the same way before. 2.4ghz is back but now VPN is not working. I re downlo...
- Dec 24, 2016*******Update*********
Swapped router today for a new one and setup everything the same except Plex Media Server. VPN is now working perfectly on iPhone and no issues with 2.4ghz channel. Hopefully I will not have any issues with this unit. If I do I will change brands and not look back. Thanks for those of you who offered help.
Hammer68
Dec 24, 2016Star
- TonyPHXDec 24, 2016Guide
Excellent outcome! Well, it shows that bad hardware can and does happen.
I bet your heart skipped a beat when it connected followed by a "I knew it!" : )
Nicely done.
