oreamunoe
Oct 07, 2020Initiate
R9000 wifi6 not working
Hi Guys I bought one router R9000 at ebay in order to upgrade my home network to use wifi 6 and 10 gb. The issue is from the router i dont see the wifi signal of 60 gh. I bought an intel ax20...
- Oct 08, 2020
Hi Guru
Thanks for your response on this. Yes it as a great router one of the best i've used.
That provided the solution to my issue.
I made a missunderstood of the standards AD to AX you're right.
Thanks a lot for your kindly response and support.
Oct 08, 2020Guru - Experienced User
1. The R9000 isn't a wifi 6 (ax) router.
2. The R9000 has a AD radio. wireless AD isn't wifi 6 either. It was kind of a dropped standard with very few routers supporting it and even less devices. It went away because wifi 6 had much better range while having comparable throughputs (speeds).
Basically you made a mistake and misunderstood wifi standards. It happens. It doesn't mean the R9000 isn't a good router. it is. But the AD radio in it is pointless for most people.
oreamunoe
Oct 08, 2020Initiate
Hi Guru
