Netcruizer
Jun 27, 2024Aspirant
R9000 with SFP+ as WAN port
Dear Community and Gurus, Has anybody actually got more than 1gbps combined on all open LAN ports, downloading concurrently, of R9000 when SFP+ is connected as WAN to a fiber 10gbps connection? ...
Jun 28, 2024Guru - Experienced User
The LAN ports on the R9000 are max rated at 1Gb each so each PC should see just over 900Mpbs. Will not see anything over 1Gb on the LAN ports.
- NetcruizerJun 28, 2024Aspirant
Thank you kindly for your reply.
But it's not clear to me from your answer.
1. That 3.6 Gigabits of data in total, i.e. 4 times x 900Mbps, would arrive at 4 PCs (that are concurrently downloading from LAN ports of R9000) after 1 second of time with SFP+ as WAN port?
2. If the above result is obtained from your actual SFP+ WAN connected to an ISP fiber connection of 10Gbps, would you be so kind provide some proof for it?
In other words, can you validate Netgear's claim of:
- Up to 10G speeds on standard RJ45 cables
when using R9000's SFP+ for wide area network (WAN) connectivity. See:
Thank you for your help in this matter. With respect.
- FURRYe38Jun 28, 2024Guru - Experienced User
I would presume that if the ISP side of the SPF port was at 10Gb connection rates, that if you had four 1Gb connected PCs connected to the 1Gb LAN ports in back, each one could see near or just over 900Mpbs on each PC while testing all at the same time.
It would seem to be a logical position to assume.
But let me to use a Thomas-inspired method in this case. Fact is it was put to me as being simply a marketing PR by Netgear of the claim cited at the link given above. It was the reason for my question of actual result as proof.
