rbport's avatar
rbport
Tutor
Mar 19, 2018
R9000 WPS button location
This may seem a stupid question but I can't find the WPS button in the router and the user manual doesn't mention its location as well. Anyone can help? Thank you in advance.
  • antinode's avatar
    antinode
    Mar 20, 2018
    > Btw, another question that I can't see amswered in the manual: all the
    > LED lights in the front are white with one exception, which is orange
    > for one of the ethernet cables.
       Page 12:
          Ethernet ports 1-4
                The LED color indicates the speed: white for Gigabit
                Ethernet connections and amber for 100 Mbps or 10 Mbps
                Ethernet connections.
       So, an amber LED indicates that that Ethernet LAN port is connected
    to a slow (slower than gigabit) device.  It could be some old/slow
    device, or it could be a gigabit interface on a device which is in
    standby ("off" or sleep) mode, where its gigabit interface is
    artificially slow, waiting for normal operation before it changes to
    gigabit speed.  (Or, a defective cable.)
       My ignorance of what's at the other end of that cable limits what
    more I can tell you.
