leandroestacio
Dec 23, 2022Aspirant
R9000 X10 Dropping Connection Speeds
Hello, so I am about to buy a new router because I cant figure it out whats going on with my router. X10 R9000 works most of the time but also at reduced speeds. I do have a gigabit connection never ...
- Dec 23, 2022
That 100M/Full status on the WAN port should be the current focus.
I am going to push again to make certain your cables are good.
Also, Ethernet port hardware has been known to go bad over time. Either in the router or the modem.
Is the firmware current? Both modem and R9000.
How long has it been since your modem has been reset?
Kitsap
Dec 23, 2022Master
leandroestacio
Router Firmware Version
V1.0.5.42
Reset as full reset it's been a while. Cables will try them. funny thing is that it works for sometime just by turning it off and back on (reset) the router. Sometimes can take days to happen again, sometimes takes like right now, 5 min
