Meob1
Jul 28, 2019Aspirant
r9000 x10 nighthawk optimal wireless settings for range
Hi All,
can anyone recommend the best setting to use for maximum range for R9000?
I am using Smart Connect
There's not much you can change in the settings to make the wifi go further.
Moving the router and putting it as high as possible in the room is the best bet.
2.4 GHz will always have a longer range.
1 Reply
