ozonexp
Jan 24, 2017Initiate
R9000 X10 VPN client
Greetings, I purchased one of your R9000 Nighthawk X10 routers. I'd like to route all my traffic through a VPN. Please tell me I didn't spend $500 on a router that doesn't support this. Third par...
- Jan 28, 2017To clarify route all my traffic through a VPN. So the router would have to be setup for as a client. DD-wrt Asus-wrt and other firmware support this.
Jan 25, 2017Guru - Experienced User
To clarify, the R9000 includes an OpenVPN server - set up to allow you to access your home network securely while you are away from home.
ElaineM
Jan 25, 2017NETGEAR Employee Retired
And to set it up, you may see the articles below.
How do I use the VPN service on my Nighthawk router with my Windows client?
How do I use VPN on my Nighthawk router with my iOS device?
How do I use VPN service on my Nighthawk router with my Android device?
- ozonexpJan 28, 2017InitiateTo clarify route all my traffic through a VPN. So the router would have to be setup for as a client. DD-wrt Asus-wrt and other firmware support this.
