PhookMi
Jul 12, 2023Aspirant
r9000
I have the R9000 Nighthawk router, everything was working fine till this morning. 2 connected desktop PC's have no internet at the ethernet point, WIFI is fine all around the house, but no internet ...
- Jul 12, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Jul 12, 2023Guru - Experienced User
PhookMi
Update:
I took all those steps, but still no internet, I called ISP to investigate as even a direct connection to PC with modem yielded no internet, they logged into modem and apparantly some code was corrupted on their end, they fixed it and I was back online!!!!!!
I appreciate your help FURRYe38
- FURRYe38Jul 12, 2023Guru - Experienced User
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
