Timlangetlc
Feb 08, 2025Follower
R9000
R9000 WiFi stopped working even though it’s checked to be on in the setup no wifi lights are on
Feb 08, 2025Guru - Experienced User
What happens if you power OFF the router for 1 minute then back ON?
Press the wifi button on top of the router for 5-10 seconds to see if this turns ON the wifi LEDs?
If that doesn't do anything, try the factory reset and setup from scratch by using the ERASE button on the RBRs web page to set up the router again from scratch.
What FW version is loaded on the router?
