shane8johnson
May 19, 2018Follower
R90000 OPENVPN Not Working on PC- but working on android
The OPEN VPN is not working on either of my PCs, but it works fine on my android phone.
By not working I mean, it says it has a connection but when I try to go to a LAN ip address on my PC, it just times out.
The logs show a fine connection.
One thing that's interesting is that on my phone is shows that the ip settings are
192.168.2.2
Defualt gateway 192.168.2.1
DNS 192.168.1.1
If I try to duplacte the above settings to my PC's NETGEAR-VPN virtual adapter, it still just times out the connection.
Ideas? I'm kind of a network guru, but this has me stumpted.
Oh, also just did an update to the the lastest firmware, and still doesn't work.
Hi shane8johnson,
What firmware version the router is currently in?
https://kb.netgear.com/000058270/R9000-Firmware-Version-1-0-4-2
- JamesGLNETGEAR Employee Retired
Hi shane8johnson,
Hi shane8johnson,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
