MilwJohn
Feb 22, 2021Follower
Radio Frequency Interference in the 2 Meter Ham Band
We have the nighthawk AC1750 router. We are having Radio Frequency Interference on the 2 meter Ham band. (146.910 mHz) How do we solve this problem. Does this product comply with FCC regulations cove...
microchip8
Feb 22, 2021Master
AC1750 is a speed, not a router model. That said, try changing channels
antinode
Feb 22, 2021Guru
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
C6300[v1] or C6300v2? Look for "Model" on the product label.
> [...] We are having Radio Frequency Interference on the 2 meter Ham
> band. (146.910 mHz) [...]
"MHz". "m" = "milli" = 1/1000. "M" = "mega" = 1000000.
> [...] Does this product comply with FCC regulations covering
> interference?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Technical Specifications" and "FCC Part 15" (which you might want to
review)?
> [...] How do we solve this problem. [...]
The usual Part-15 remedy is to remove power from the offending
device. You could try shielding.
> [...] try changing channels
Harmless enough to try, but I wouldn't expect much output in the 2m
band from a 2.4GHz or 5GHz transmitter, regardless of its channel. I
know nothing, but I'd expect signals in that band to be spurious stuff
from the CPU and other computery stuff in the gizmo, rather than its
wireless-network radios.
