amrashraf
Feb 01, 2021Aspirant
Radius problem
i have netgear model R6850 firmware V1.1.0.78_1.0.1 ihave problem i activated radius server on my netgear everything work perfect but when i dissconnect wifi from my phone and reconnect after hou...
Jun 27, 2022Guru - Experienced User
Does using a non radius WPA2 configuration work?
Not much radius configurations seen on Home class routers. Something more in tune with small or larger business class wifi systems
- amrashrafJun 29, 2022Aspirant
you mean this model r6850 dosnot support radius...... i try another access point(ip time) every thing is good idont know what is the problem with netgear!!
- FURRYe38Jun 29, 2022Guru - Experienced User
Be sure your using most current version of FW.
Might contact NG support regarding this however that model router is getting to be a bit older and may not be fully supported anymore.
Something to ask NG support about.
