amrashraf
Feb 01, 2021Aspirant
Radius problem
i have netgear model R6850 firmware V1.1.0.78_1.0.1 ihave problem i activated radius server on my netgear everything work perfect but when i dissconnect wifi from my phone and reconnect after hou...
Jun 27, 2022Guru - Experienced User
Does using a non radius WPA2 configuration work?
Not much radius configurations seen on Home class routers. Something more in tune with small or larger business class wifi systems
amrashraf
Jun 29, 2022Aspirant
you mean this model r6850 dosnot support radius...... i try another access point(ip time) every thing is good idont know what is the problem with netgear!!
- FURRYe38Jun 29, 2022Guru - Experienced User
Be sure your using most current version of FW.
Might contact NG support regarding this however that model router is getting to be a bit older and may not be fully supported anymore.
Something to ask NG support about.
