ABrewer91
Jun 15, 2021Aspirant
Random Disconnects
Hello there, First off, thanks for taking the time to read through this. Any information any of you have will be greatly appreciated. So... for quite awhile now, maybe 2 years? I've had ra...
Jun 15, 2021Guru - Experienced User
1. what modem do you have?
2. Does the issue happen if directly wired to the modem?
3. you have the R7000P?
4. What firmware is on the router?
- ABrewer91Jun 16, 2021Aspirant- My modem is the Netgear CM1000
- I've never tried directly to the modem
- Yes, the Nighthawk R7000P
- It's the most recent firmware as I made sure to do an update check as a troubleshooting means.- plemansJun 16, 2021Guru - Experienced User
An actual firmware number helps. Since that router has had a couple firmware issues.
Try it with wired devices as well to see if its just a wireless vs wired issue
- ABrewer91Jun 16, 2021AspirantI won't be able to get you an actual firmware # until later when I get home. As far as the wired vs wireless, I'm always hard wired, my PC is never on wifi.
