ABrewer91
Jun 15, 2021Aspirant
Random Disconnects
Hello there, First off, thanks for taking the time to read through this. Any information any of you have will be greatly appreciated. So... for quite awhile now, maybe 2 years? I've had ra...
ABrewer91
Jun 24, 2021Aspirant
Sorry for the long interval between responses. I THOUGHT the problem had been fixed after a factory reset but it came back tonight. Here's the firmware version that the router is running;
V1.3.1.64_10.1.36
V1.3.1.64_10.1.36
Jun 25, 2021Guru - Experienced User
you could try the latest 1.3.2.134 version.
https://www.netgear.com/support/product/R7000p
Or the one I'd recommend if there's still issues is the 1.3.0.20 version. its the version prior to netgear armor.
the both the r7000 and r7000p, I'd recommend installing over a hardwired connection and doing a factory reset/reinstsall afterwards for best results.
