Ezie
Jun 06, 2021Aspirant
Random internet disconnects of hardwire and wi-fi modelR6400v2
I bought this router because I started working from home and needed to hardwire my office computer. A few days after I noticed it would randomly disconnect all devices hardwired or using Wi-fi. The n...
Jun 07, 2021Guru - Experienced User
what gateway from metronet do you have?
Ezie
Jun 07, 2021Aspirant
default gateway is 192.168.1.1
- michaelkenwardJun 08, 2021Guru - Experienced User
That is the default local IP address for whatever your router is.
The "gateway" that plemans asked about is the modem, modem/router or whatever it is that connects you to the Internet.
You said earlier:
I also have Metronet ISP fiberoptic.
I this the thing that feeds the Internet to your router? Is there some sort of box on the wall that you plug into?
In general, I find it very difficult to follow your message. What is this "old modem" supposed to tell us? The R6400v2 is a router. No modem in sight.
- EzieJun 08, 2021Aspirant
My apologies, I meant to say old router not modem. The default local IP address is 162.211.34.143
Again, we still do not know what you use to connect to the Internet. The hardware, not the address.
