Ezie
Jun 06, 2021Aspirant
Random internet disconnects of hardwire and wi-fi modelR6400v2
I bought this router because I started working from home and needed to hardwire my office computer. A few days after I noticed it would randomly disconnect all devices hardwired or using Wi-fi. The n...
Ezie
Jun 07, 2021Aspirant
default gateway is 192.168.1.1
michaelkenward
Jun 08, 2021Guru - Experienced User
That is the default local IP address for whatever your router is.
The "gateway" that plemans asked about is the modem, modem/router or whatever it is that connects you to the Internet.
You said earlier:
I also have Metronet ISP fiberoptic.
I this the thing that feeds the Internet to your router? Is there some sort of box on the wall that you plug into?
In general, I find it very difficult to follow your message. What is this "old modem" supposed to tell us? The R6400v2 is a router. No modem in sight.
- EzieJun 08, 2021Aspirant
My apologies, I meant to say old router not modem. The default local IP address is 162.211.34.143
- michaelkenwardJun 08, 2021Guru - Experienced User
Again, we still do not know what you use to connect to the Internet. The hardware, not the address.
