Superannuated
Mar 07, 2023Aspirant
Random Loss of Internet
I have an #R8500 that's worked fine for several years. Suddenly it's apparently losing the Internet connection. The WiFi light (rightmost) on the router is on, but the other two are off when in nor...
Mar 07, 2023Guru - Experienced User
What other LEDS are off? Power or Internet?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
