ashleyxxa
Dec 29, 2020Guide
Random ping spikes on Wifi (not ethernet) every ~15 minutes when streaming on Mac OSX
Normally I have about 30ms ping when gaming on my mac, but about every 15 minutes I get a huge ping spike from 400ms to 3000ms for about a 2 minute period of time. I haven't changed any router settin...
- Jan 07, 2021
I have resolved the issue. After testing my internet streaming connection on other apps it was something to do with a bug in the specific streaming app I was using. After deleting and re-installing the offending app it resolved itself.
ashleyxxa
Dec 29, 2020Guide
Update: After more testing to see what is trying to get access to data, I have found I can actually control the ping spikes by throttling my wifi download speed. If I stream at 70mbps my ping spikes to 3000ms but if I throttle down to 15mbps it goes back down to the average of 30ms ping.
This is odd because it has previously been working over wifi fine. I have deduced by this that it indeed has something to do with the router. I assume that the bandwidth is overwhelming the wifi and that is what is causing the spike. Which is odd because it works fine most of the time.
ashleyxxa
Jan 07, 2021Guide
