Smoothride
Jan 04, 2022Follower
Range Extender Router & Device Link LEDs - ON, No Connection
Hi All, Background: I currently have an LG TV connected to a Netgear Wireless Modem/Router but wanted to improve the signal. Purchased an EX3700 with that intent. So I connected the EX3700 to ...
michaelkenward
Jan 05, 2022Guru - Experienced User
A lot of devices, especially routers, have generic problems that can be answered in any section, But in the case of the EX3700 we are talking about a wifi extender. And these can be a pig to set up.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
So I connected the EX3700 to the router using WPS and the Router Link LED shined steady Green.
Do other wifi devices connect to the extender? If not that would help to rule out the TV as the problem.
By the way, when I wanted to get a "smart" Samsung device to connect to the Internet, I invested in Powerline Ethernet and used a pair of plugs over the mains circuit.
