solson28
Jan 01, 2021Follower
Range Extender that works well with Nighthawk CAX80/AX6000
We have a Nighthawk CAX80/AX6000 that we use with spectrum internet service, we have the maximum speed 400 mbps that they provide in this area. It works great for our top floor, but it struggles to r...
Jan 02, 2021Guru - Experienced User
I haven't used any of the line of AX extenders but I have used the EX8000 and other single/dual band extenders. I'd highly recommend the triband line of extenders. They don't suffer from the same throughput loose that single/dual band extenders do because they have a dedicated backhaul between router----extender.
In terms of performance, the EX7500/EX7700/EX8000/RBS40V all are going to perform at least as good if not better than the EAX20 based on specs and testing I've seen. Not sure about the EAX80. Someday maybe I'll buy one to play with and compare.
All of them should function well with the CAX80 and your 400mbps speeds.
