uzisuicide27
Oct 22, 2021Follower
RAX120 VPN and Tunnelblick Issues
Hello,
I followed the instructions on installing tunnelblick and the openvpn package from routerlogin.net but it doesn't appear to be working. I'm not sure what step I missed. Any help would be appreciated. Here is the diagnostic log. Oh I'm also using a Mac running Big Sur 11.3. Thank you for any help you could provide!
*Tunnelblick: macOS 11.3 (20E5231a); Tunnelblick 3.8.6a (build 5711); prior version 3.8.3a (build 5521); Admin user
git commit bfa5710de5b21c3b12acdb01f7d00c0ed953ec9e
The Tunnelblick.app process is not being translated (x86_64)
System Integrity Protection is enabled
Configuration vpn
"Sanitized" condensed configuration file for /Users/Joe/Library/Application Support/Tunnelblick/Configurations/vpn.tblk:
client
dev tap
proto udp
remote JVallon.mynetgear.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
remote-cert-tls server
auth-nocache
cipher AES-128-CBC
comp-lzo
verb 5
script-security 2
up dhcp-client-request.sh
Files in vpn.tblk:
Contents/Resources/cli….crt
Contents/Resources/ca.crt
Contents/Resources/config.ovpn
Contents/Resources/dhcp-client-request.sh
Contents/Resources/cli….key
Tunnelblick Kext Policy data
net.tunnelblick.tap|Z2SG5H3HC8|Jonathan Bullard|1|1
net.tunnelblick.tun|Z2SG5H3HC8|Jonathan Bullard|1|1
Configuration preferences:
-routeAllTrafficThroughVpn = 1
-notOKToCheckThatIPAddressDidNotChangeAfterConnection = 0
-lastConnectionSucceeded = 0
Wildcard preferences:
Program preferences:
launchAtNextLogin = 1
tunnelblickVersionHistory = (
"3.8.6a (build 5711)",
"3.8.3a (build 5521)"
lastLaunchTime = 656632634.576057
lastLanguageAtLaunchWasRTL = 0
connectionWindowDisplayCriteria = showWhenConnecting
maxLogDisplaySize = 102400
keyboardShortcutIndex = 1
updateCheckAutomatically = 1
NSWindow Frame ConnectingWindow = 1085 898 389 217 0 0 2560 1415
NSWindow Frame SUUpdateAlert = 970 762 620 398 0 0 2560 1415
detailsWindowFrameVersion = 5711
detailsWindowFrame = {{631, 230}, {920, 522}}
detailsWindowLeftFrame = {{0, 0}, {167, 402}}
detailsWindowViewIndex = 0
detailsWindowConfigurationsTabIdentifier = log
leftNavSelectedDisplayName = vpn
AdvancedWindowTabIdentifier = sounds
haveDealtWithOldTunTapPreferences = 1
haveDealtWithAlwaysShowLoginWindow = 1
haveDealtWithOldLoginItem = 1
haveDealtWithAfterDisconnect = 1
SUEnableAutomaticChecks = 1
SUScheduledCheckInterval = 86400
SULastCheckTime = 2021-10-22 21:57:20 +0000
SUHasLaunchedBefore = 1
WebKitDefaultFontSize = 16
WebKitStandardFont = Times
Forced preferences:
(None)
Deployed forced preferences:
(None)
Tunnelblick Log:
2021-10-22 18:11:14.850444 *Tunnelblick: macOS 11.3 (20E5231a); Tunnelblick 3.8.6a (build 5711); prior version 3.8.3a (build 5521)
2021-10-22 18:11:15.142093 *Tunnelblick: Attempting connection with vpn using shadow copy; Set nameserver = 769; monitoring connection
2021-10-22 18:11:15.142536 *Tunnelblick: openvpnstart start vpn.tblk 62201 769 0 1 0 34653042 -ptADGNWradsgnw 2.5.3-openssl-1.1.1l
2021-10-22 18:11:15.160225 *Tunnelblick: openvpnstart starting OpenVPN
2021-10-22 18:11:18.751852 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
2021-10-22 18:11:18.752162 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning.
2021-10-22 18:11:18.752499 OpenVPN 2.5.3 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Sep 1 2021
2021-10-22 18:11:18.752522 library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10
2021-10-22 18:11:18.753451 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:62201
2021-10-22 18:11:18.753484 Need hold release from management interface, waiting...
*Tunnelblick: Some entries have been removed because the log is too long
JVallon.mynetgear.com:12974 (nodename nor servname provided, or not known)
2021-10-22 18:19:25.002422 MANAGEMENT: >STATE:1634941165,RESOLVE,,,,,,
2021-10-22 18:19:25.003107 RESOLVE: Cannot resolve host address: JVallon.mynetgear.com:12974 (nodename nor servname provided, or not known)
2021-10-22 18:19:25.003120 Could not determine IPv4/IPv6 protocol
2021-10-22 18:19:25.003159 SIGUSR1[soft,init_instance] received, process restarting
2021-10-22 18:19:25.003168 MANAGEMENT: >STATE:1634941165,RECONNECTING,init_instance,,,,,
2021-10-22 18:19:25.003205 MANAGEMENT: CMD 'hold release'
2021-10-22 18:19:25.003218 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2021-10-22 18:19:25.003253 MANAGEMENT: >STATE:1634941165,RESOLVE,,,,,,
2021-10-22 18:19:25.004059 RESOLVE: Cannot resolve host address: JVallon.mynetgear.com:12974 (nodename nor servname provided, or not known)
2021-10-22 18:19:25.004093 MANAGEMENT: >STATE:1634941165,RESOLVE,,,,,,
Down log:
(Not found)
Previous down log:
(Not found)
Network services:
An asterisk (*) denotes that a network service is disabled.
SAMSUNG Modem
Ethernet
Wi-Fi
Bluetooth PAN
Thunderbolt Bridge
Wi-Fi Power (en1): On
ifconfig output:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
ether 80:4a:14:62:d6:67
inet6 fe80::b9:37b9:e895:df8a%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.1.18 netmask 0xffffff00 broadcast 192.168.1.255
media: autoselect (1000baseT <full-duplex,flow-control,energy-efficient-ethernet>)
status: active
ap1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether a6:83:e7:aa:0d:9a
media: autoselect
status: inactive
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether a4:83:e7:aa:0d:9a
inet6 fe80::802:1b1c:9a9f:8dc4%en1 prefixlen 64 secured scopeid 0x6
inet 192.168.1.21 netmask 0xffffff00 broadcast 192.168.1.255
media: autoselect
status: active
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=460<TSO4,TSO6,CHANNEL_IO>
ether 82:8b:dd:e4:a8:00
media: autoselect <full-duplex>
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:8b:dd:e4:a8:01
status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 7 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 8 priority 0 path cost 0
media: <unknown type>
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 76:83:57:9e:e4:1d
inet6 fe80::7483:57ff:fe9e:e41d%awdl0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::7483:57ff:fe9e:e41d%llw0 prefixlen 64 scopeid 0xb
media: autoselect
status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::d96a:9784:2ae7:3cdf%utun0 prefixlen 64 scopeid 0xc
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::c419:8b6:207e:f4ad%utun1 prefixlen 64 scopeid 0xd
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::4f69:c112:aaf7:3c20%utun2 prefixlen 64 scopeid 0xe
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::eb0a:2985:2ef:c198%utun3 prefixlen 64 scopeid 0xf
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::d3f9:4627:b005:3d5b%utun4 prefixlen 64 scopeid 0x10
utun5: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::915f:1d95:cb86:655%utun5 prefixlen 64 scopeid 0x11
Non-Apple kexts that are loaded:
Index Refs Address Size Wired Name (Version) UUID <Linked Against>
191 0 0xffffff7f9b562000 0x6000 0x6000 net.tunnelblick.tap (5.0) 2FF3CB18-848D-39B0-B14D-F04B0128E023 <8 6 5 1>
192 0 0xffffff7f9b569000 0x6000 0x6000 net.tunnelblick.tun (5.0) 39EBE984-8A8F-39CF-BA60-4B1A249AB7EC <8 6 5 1>
Quit Log:
2021-10-22 17:53:12.845445 applicationShouldTerminate: termination because of restart; delayed until 'shutdownTunnelblick' finishes)
2021-10-22 17:53:12.888912 shutDownTunnelblick: started.
2021-10-22 17:53:12.889248 shutDownTunnelblick: Starting cleanup.
2021-10-22 17:53:12.889748 cleanup: Entering cleanup
2021-10-22 17:53:12.892091 synchronized user defaults
2021-10-22 17:53:14.153286 Set up flag files for shutting down the computer and expecting all configurations to be disconnected
2021-10-22 17:53:14.189781 doDisconnectionsForShuttingDownComputer: Set 'expect disconnect 1 ALL'
2021-10-22 17:53:14.190105 Started disconnecting all configurations
2021-10-22 17:53:14.190459 Skipping cleanup because computer is shutting down or restarting
2021-10-22 17:53:14.190857 shutDownTunnelblick: Cleanup finished.
2021-10-22 17:53:14.191190 Finished shutting down Tunnelblick; allowing termination
Console Log:
2021-10-22 17:47:07.033343 Tunnelblick[6752] Tunnelblick: macOS 10.16.0; Tunnelblick 3.8.3a (build 5521)
2021-10-22 17:47:07.036557 Tunnelblick[6752] Error returned from setAttributes: {
NSFilePosixPermissions = 488;
} ofItemAtPath: /Users/Joe/Library/Application Support/Tunnelblick/Configurations; Error was Error Domain=NSCocoaErrorDomain Code=513 "You don’t have permission to save the file “Configurations” in the folder “Tunnelblick”." UserInfo={NSFilePath=/Users/Joe/Library/Application Support/Tunnelblick/Configurations, NSUnderlyingError=0x6000000eb6f0 {Error Domain=NSPOSIXErrorDomain Code=1 "Operation not permitted"}}; stack trace: (
0 Tunnelblick 0x0000000101f6e1fa -[NSFileManager(TB) tbChangeFileAttributes:atPath:] + 161
1 Tunnelblick 0x0000000101fb3757 createDir + 573
2 Tunnelblick 0x0000000101f3c06e -[MenuController init] + 6019
3 AppKit 0x00007fff22f9d5a4 -[NSCustomObject nibInstantiate] + 404
4 AppKit 0x00007fff22f9d3b3 -[NSIBObjectData instantiateObject:] + 238
5 AppKit 0x00007fff22f9cb12 -[NSIBObjectData nibInstantiateWithOwner:options:topLevelObjects:] + 484
6 AppKit 0x00007fff22f91578 loadNib + 392
7 AppKit 0x00007fff22f90b84 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:options:withZone:ownerBundle:] + 693
8 AppKit 0x00007fff22f907da -[NSBundle(NSNibLoading) loadNibNamed:owner:topLevelObjects:] + 201
9 AppKit 0x00007fff22f905b8 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 394
10 AppKit 0x00007fff22f83126 NSApplicationMain + 566
11 Tunnelblick 0x0000000101f25a98 start + 52
12 ??? 0x0000000000000001 0x0 + 1
2021-10-22 17:47:07.036614 Tunnelblick[6752] Warning: Unable to change permissions from 755 to 750 on /Users/Joe/Library/Application Support/Tunnelblick/Configurations
2021-10-22 17:47:09.247857 Tunnelblick[6752] Sparkle: ===== Tunnelblick =====
2021-10-22 17:47:09.248163 Tunnelblick[6752] Sparkle: Verified appcast signature
2021-10-22 17:47:09.425916 Tunnelblick[6752] Configuration 'client' requires a 'tap' system extension
2021-10-22 17:47:12.212762 Tunnelblick[6752] Sparkle: Extracting using '/usr/bin/ditto' '-x' '-k' '-' < '/Users/Joe/Library/Caches/net.tunnelblick.tunnelblick/org.sparkle-project.Sparkle/Tunnelblick 5711/Tunnelblick_3.8.6a_build_5711.zip' '/Users/Joe/Library/Caches/net.tunnelblick.tunnelblick/org.sparkle-project.Sparkle/Tunnelblick 5711'
2021-10-22 17:47:14.089402 Tunnelblick[6752] updater:willInstallUpdate: Starting cleanup.
2021-10-22 17:47:14.089457 Tunnelblick[6752] cleanup: Entering cleanup
2021-10-22 17:47:14.090114 Tunnelblick[6752] synchronized user defaults
2021-10-22 17:47:14.376176 Tunnelblick[6752] Set 'expect disconnect 0 ALL'
2021-10-22 17:47:14.888302 Tunnelblick[6752] updater:willInstallUpdate: Cleanup finished.
2021-10-22 17:47:14.978693 Tunnelblick[6752] cleanup: Entering cleanup
2021-10-22 17:47:14.978984 Tunnelblick[6752] pthread_mutex_trylock( &cleanupMutex ) failed; status = 16, errno = 22
2021-10-22 17:47:14.979032 Tunnelblick[6752] pthread_mutex_trylock( &cleanupMutex ) failed is normal and expected when Tunnelblick is updated
2021-10-22 17:47:14.980761 Tunnelblick[6752] Finished shutting down Tunnelblick; allowing termination
No RepliesBe the first to reply
