user_I_mean_bot
Jan 31, 2022Follower
RAX120 with slow upload - big Jitter
I have a RAX120, with Comcast. When I can perform speed tests (not always available) I get a big jitter with 0 (or nearly 0) upload speed. The signal is very intermittent and I have to restart m...
Jan 31, 2022Guru - Experienced User
Be sure to speed test and check tests results with a wired PC connected to the modem with out the router connected.
Be sure to use good quality LAN cable. CAT6 is recommended.
Test with a different wired PC to compare results.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
