Hiro_j
Oct 07, 2021Initiate
RAX200 APモード時のsmart connectについて
現在以下のような構成で利用しています。 インターネット | ONU | 有線ルーター(ここにDHCPサービスあり) | GS308P(HUB) | RAX200(APモード) この状態でsmart connectをONにすると、IPアドレスが取れないことがあります。 無線の接続はできていてアドレスだけ取れず169.*.*.*のアドレスになって...
Oct 08, 2021Guru - Experienced User
I've got an RAX200 running in AP mode and not ran into that issue.
Does it happen if smart connect is disabled?
when did it start?
What device is acting as router/dhcp server?
- Hiro_jOct 09, 2021Initiate
Thanks for your reply.
When smart connect is disabled, it doesn't happen.The first, my iPhone (or iPad) connected.
It got IP address correctly.
Next, I turned off the wi-fi switch on the smart phone,
And turned on the switch.
It couldn't get IP address correctly.The functions ( Router and DHCP ) runs on 有線ルーター.
Sorry for all repliers.
I have posted it on the English community by mistake.
