sutphinwb
Jan 21, 2022Aspirant
RAX200 In Wifi unfriendly environment
I installed this router in a bad spot. Unfortunately I've no other choice. I was hoping coverage would be a little better but it isn't. So now I'd like to know if this router can be used with mesh...
Jan 21, 2022Guru - Experienced User
You could use your current orbi 50 series with it.
What speeds do you pay for?
You have a couple options.
1. use the RAX200 as the primary router (in its crappy location) and use the RBK50 series in access point mode. You'd have peak speeds at the RAX200 but still coverage around the home.
2. Use the RBK50 as the primary. the RBK50 has a pretty wide backhaul (1733mbps link speed, not throughput). Potentially you could put one of the satellites in the area you want peak wireless coverage and if its backhaul was fast enough, wire the RAX200 to it with the RAX in access point mode. Then you could use its wireless for AX coverage.
A lot just depends on the speed your paying for and how well the satellite connects to the orbi router. If the satellite can max out your ISP speeds while hardwired, the RAX would do great. If its only pulling in partial speeds, then option 1 would probably be better.
