Klopez79's avatar
Klopez79
Rax200 range extender
I currently have the nighthawk RX 200 router and I'm looking to get a range extender. Which one is the best one? If I get a mesh satellite it has to be used with the mesh system router correct?
  • plemans's avatar
    Jan 20, 2021
    I'd recommend either the AX extender (EAX15, EAX20, EAX80) or one of the triband AC ones (EX7500, EX7700, EX8000).
    I've used the EX8000 with my RAX200 and it worked great.
