miztrniceguy
Oct 19, 2021Aspirant
RAX40 throttled on wifi and LAN
I have a Nighthawk RAX40. I just moved and am not getting the speeds I should. At previous address about 2.5 miles away I had the same internet package with Spectrum for 400Mbps and consistently got ...
Oct 20, 2021Guru - Experienced User
have you tried replacing the cable between the modem and router?
I've seen sketchy cat 5e cables not connect at gigabit speeds.
You can check your wan port statistics.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
