Philaretordre
Jan 23, 2022Tutor
RAX40V2 / Interface Web configuration
Bonjour, Je souhaite savoir comment configurer mon routeur en passant (via un ordinateur) par la page web de configuration accessible en entrant l'ip du routeur. Je ne veux pas passer par l'utili...
- Jan 24, 2022
Hi, yes i just have desactivated temporarily my vpn to access to routeurlogin.net. If I don't do that i'm redirected to netgear.com.
Jan 23, 2022Guru - Experienced User
You can set it up via the browser. when it gives you the notice to use the app, if you scroll down on the page, you'll see a notice "i don't have a phone" or something along those lines. click the link and you'll be able to setup with the browser
- PhilaretordreJan 23, 2022Tutor
Finally, i found the solution. I had to desactivate my VPN and now i can access to the configuration page by typing routeurlogin. Thx.
- JarrellJan 24, 2022Aspirant
Is that worked for you i have same issue and looking for answer must share what youdo for it mygiftcardsite
- PhilaretordreJan 24, 2022Tutor
- plemansJan 24, 2022Guru - Experienced User
That would make a bit of difference!
glad you got it setup. You can mark it solved so others aren't trying to fix it and it could help the next person with this issue.
