MelissaAlex24
Sep 04, 2021Aspirant
RAX43 — Nighthawk AX5 5-Stream AX4200 WiFi Router
I am unable to connect my router to my internet. Can’t work out how to do it and have followed the instructions and troubleshoots. Anyone else had this issue and know how to fix it at all
Sep 04, 2021Guru - Experienced User
What modem/gateway are you connecting it to?
What error/issue are you running into in detail? "won't connect" doesn't tell us much.
MelissaAlex24
Thanks for the reply. I’m trying to set it up from the start in the app and connect the router to the internet connection (my internode internet) and just fails every time. It comes up with cables correct then goes to internet not detected. I’ve followed the set up as per instructions.
I then go to advance settings and click PPPoE try to connect using my login password and still fails.
I hope this is enough information for your help
- microchip8Sep 04, 2021Master
Don't use stupid and limited apps, no matter what NG wants you to use. When configuring a router, it's best to use its Web UI at http://routerlogin.net or http://192.168.1.1
- michaelkenwardSep 05, 2021Guru - Experienced User
MelissaAlex24 wrote:
my internode internetDoes that have some sort of box that connects to the outside world?
A modem? Make and model?
