MortJared
Oct 15, 2021Aspirant
RAX45 Can't change DNS Servers
RAX45
Firmware Version V1.0.2.82_2.0.50
We use web content filtering through a DNS server (or used to until we replaced our router), However I am unable to change the DNS settings on this router. The option to "use these DNS servers" is unselctable. I can click and click on it and it doesn't to anything. I can fill out the servers, but still unable to select the option to use them. When I select "apply" or "test" it does something for 30 seconds thens comes back to the screen with no changes saved.
what modem/gateway are using?
are you using the IPv6 settings?
Is Armor enabled on the routers web page?
What browser are you using?
MortJared wrote:
RAX45
