amonynuts's avatar
amonynuts
Apprentice
Jan 14, 2022
RAX45 Can't disable Anywhere Access Remote Management
Nighthawk RAX45-100NAS AX4300 AX6 Nighthawk, Firmware V1.0.5.106_2.0.70
Why is there no option to disable Anywhere Access (Remote Management) in the Web Management portal (routerlogin.net)?  I can disable Anywhere Access in the Nighthawk app (which breaks the app BTW), but the setting only seems to be saved in the app, since it's magically re-enabled each time I reinstall the app.  For security reasons, I'd rather that my router wasn't continually polling the Netgear cloud to check if there's any management scripts to run.
Perhaps there's some Netgear cloud IP address I could block?
