austex2021
Sep 04, 2021Follower
RAX45 doesnt reach 200 mbps on 2.4G
Just got a new RAX45 and like others the 2.4G does not reach 200MBPS (the 5G does reach it)
1. QoS is off
2. Docsis 3.0 modem
I try to use the 5G as much as I can but from time 2 time the connection moves to the 2.4G and its connection speed is a paltry 35-40mpbs
Feedback Appreciated. Thanks
the 2.4ghz won't reach 200mbps.
2.4ghz is a slow network that also suffers from more interference that 5ghz.
the benefit to it is that it broadcasts further and through more materials. But this is also a con as thats what causes increased interference with other 2.4ghz networks.
You can try optimizing by choosing a wifi channel for the 2.4ghz that is te least used.
As plemans says, you have discovered one of the laws of physics.
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
Speed freaks should go out of their way to use wired connections.
