cestmoijay
Dec 08, 2021Aspirant
RAX45 new firmware 1.0.4.100 - not showing Web Services Management info after upgrade??
Hello
I just upgraded my RAX45 from 1.0.2.82_2.0.50 to 1.0.4.100_2.0.64 and when I navigated to Web Services Management section to see if it's enabled or not, and lo and behehold, I can only see "Always Use HTTPS to Access Router"... nothing else!
This new firmware has a bug or is it my browser? This is occuring on both Chrome and Firefox and Microsoft's Edge all on latest versions.
What gives??!
Not sure what you mean by "web services management"
NG seems to be moving away from "Remote Management" features to "Web Services Management" features. Which seems to be to only enable or disable it. This means that you can access the router from remote locations only by using the NightHawk app. Seems that Web browser remote access support is being removed or remote locations.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
cestmoijay wrote:
Hello
What gives??!
