Raishaun
Jan 02, 2022Tutor
RAX50 AX5400 no internet connection
My RAX50 just randomly lost internet connection. Internet light is solid red. Since this has happened I've fsctory reset countless times. I managed to find out the nighthawk app was preventing it fro...
- Jan 02, 2022
The cm1200 has 4x ethernet ports. But comcast only supports 1 device connected to it.
So try this. Power off the router and the modem. Disconnect the coax from the modem.
Wait 2 minutes.
Connect the coax back to the modem and power it on.
Wait 2 minutes.
Connect port 1 on the modem to the wan port on the router.
Power the router on.
Wait 2 minutes for it to fully boot.
Attempt setup/using the router.
Make sure to only have 1 device plugged into the cm1200.
Raishaun
Jan 02, 2022Tutor
At one point I had my ps5, and an amason fire cube plugged into the cm1200 and it ran fine. I recently had an outage, and when it came back up nothing was working for awhile. Do you have any recomendations on getting around this aside from getting a router with more ports?
Jan 02, 2022Guru - Experienced User
The CM1200 doesn't have a router as mentioned already, so connecting the RAX50 to the CM1200 port #1 will work. Then connect ALL other wired and wireless devices to the RAX router.
- plemansJan 02, 2022Guru - Experienced UserIf you're needing more ports for the router, they make pretty cheap unmanaged gigabit switches
