Breiz's avatar
Breiz
[RAX70] Wifi - SSID 5G-2 in Mode 'Up to 4803 Mbps' doesn't show up
Hi,   I have noticed a quirk in the wifi setup on the RAX70 with regards to the 5G-2 SSID.   When I select the Mode 'Up to 4803 Mbps', it takes ages for the SSID to show up and you can't connect ...
  • plemans's avatar
    Jan 05, 2022
    do you live in an area with radar (military, weather, or satellite communication)? the "up to 4800" speed requires the use of DFS channels which have certain restrictions. When the router boots up, it has to scan/check those channels before it can broadcast on them (takes longer). And if it senses those channels in use with radar, it can't use them until a set period of time after they've stopped broadcasting.
